Okay,
I just installed a Warn Full float kit on my bronco.
The install requires detaching the rear brake lines from the brake cylinders and taking the entire backing plate with drum brake components off and setting it aside to put on the spindles.
Now everything went fine until I was hooking the brake lines back up and bleeding the system.
Keep in mind this entire axle is only 1-2 years old. I bought a 76 rear axle and replaced everything on it. Before the Warn upgrade the Bronco drove perfectly fine, no brake issues what so ever.
Like I said, everything was fine until I was bleeding the system. I started at the passenger rear drum, this one bled just fine, no air bubbles. Went to the driver rear drum and every time I hit the brake pedal, it looks okay until about half stroke and then a little bevy of bubbles runs through the bleed tube, as much as I bleed it, it never stops.
Two questions:
1) What the heck is going on? This brake cylinder should NOT be bad, I do not see any leaks anywhere. And it is only 1-2 years old.
2) What is the best apparatus used to bleed the brake system. I bought the el-cheapo Autozone plastic bottle on a magnet and plastic hose set up. Everytime I have bled the brakes on this rig for the past 3.5 years, I have had NO problems. NOW I do. I find it hard to believe that it is my bleeding aparatus, but I don't want to eliminate any options.
Please help me out where you can...
Thanks,
Chris
Two questions:
Thanks,
Chris
