Rustytruck said:
My 74 came with a carb insulating gaskit from Ford so it already had longer studs. My engine is a california smog motor with egr but with the fuels we now have hot restart vapor locking got me to a boiling point. I replaced it all with a 289 4 barrel cast iron manifold with adapter and now run a quadrajet. the quad has been on for 4 years now without touching it and the only issue I have had is long term sitting. the small fuel bowl dries out in about 2 weeks time and the first time you start it you have to crank it a little. Other than that the next best option is fuel injection but that is far too unreliable and expensive for me. Good for the street where tow trucks are available but not for someone who goes 75 miles past nowhere.
Modern EFI has built in backup systems for almost everything. Most of the sensors can fail, and it will still work, it won't make max horsepower but it will get you back. It's calle "Limp Mode".
Factory EFI systems are designed for 50,000miles between tune ups. Carbed cars need it about every 10,000 ( or more often). Warranties on cars are longer now than they were in the 70s, and EFI has a part in that.
The items that aren't covered by limp mode are the distributor, ( same as on a carb'd engine), the fuel pump ( not much different that a carb'd engine) and the computer ( not much different than an ignition module on the duraspark setups). I carry a spare HP fuel pump, a spare computer and a spare TFI module. When I ran a carb'd rig I carried a spare ignition module, and a spare electric fuel pump. Not much different.
When I had a carbed rig I had to adjust it every trip. EFI just goes and goes.
What is different is that most shade tree mechanix know how to fiddle with a carb and get it to work. The same isn't true of EFI. If your not comfortable with EFI, then I'm ok with that, but don't blame in on EFI reliability.
Tom
