1973 Bronco 6 port fuel selector switch
Mackay
Hoping to solicit help for replacing the stock 6 port fuel selector switch on my 1973 Ford Bronco. It appears only a 3 port replacement is available. What do I do with the three remaining return fuel vent lines? Any help is appreciated more than you know!
Oldtimer
Jr. Member with Sr. moments
Sunnyvale, CA
Check out this thread:
I'll ask the question, do you need the return lines? It was a 1-year only item.
If you want to keep it an original mechanical fuel selector valve, swap the fuel pump (or is it filter? I forget where the return line originates from) for a non-73 model and cap the return ports going to the tanks. Run it as a 3-port setup.
It was a bespoke cylindrical thingy with ports coming and going, that lived up by the carburetor. Sort of hung out there between the distributor and the pump, on its way to the carb.
Personally, I’d keep it and just change the original valve to a six port electric. That’s what I have on mine, even without the return plumbing. I had always intended to add it, but never quite got around to it.
Is something wrong with your existing switching valve? Are you handy enough to try rebuilding it? If it’s just leaking, that might be the ticket.
thegreatjustino
Red Head Grease Monkey
Stockton, CA
You can see the 90 degree fitting for the return line right behind the distributor cap.
