Fuel Filter Question
Trapperbob10
Will inline threaded fuel filter cannisters normally used on EFI vehicle work on my '73 with mechanical fuel pump?
Thanks in advance.
Regards,
Trapperbob
T
Trapperbob10
Not exacty that one but the the principal should be the same. My concern was that the EFI vehicles that run the filter I am planning on using all have fuel tank mounted pumps that push the gas vs my mechanical pump that pulls the fuel.
Regards,
Trapper
broncow72
Village Idiot
Spring,TX.
Oh, I know the one you're talking about. I think they can be used if you block off a couple ports. I assume you are wanting to go this route with the intention of upgrading to Fi in the future?
T
Trapperbob10
No, I am happy with carburated/ mechanical fuel pump Bronco/old school I guess.
What I am looking to upgrade is my fuel line/filter situation. Have a good Earls 35 micron before the carb and in addition, have been running a cheap napa inline on the fuel line.
In the process of upgrgading the fuel line from rubber hose to steel line. Have replaced the cheap napa plastic inline filter with a metal cannister inline(also from napa).
My main concern was the use of mechanical pump vs tank mounted electric pump.
Have got the filter mounted and will do a volume test before i finish the upgrade.
Thanks for your responses,
Regards,
Trapper
So you are just wanting to know if an EFI filter will work in a normal carb application?
If that is the correct question, then yes it will. It is a finer filter, but it is also larger. It is a toss up if you will get longer life out of the filter that way, but you should have cleaner fuel in the carb while finding out.
T
Trapperbob10
Yep, that was the question and cleaner fuel is the goal. Debris in the carb. is a roya PITA.
Regards,
Trapper
