Fuel gauge problem
Bronk74
North Las Vegas
i know i know you all been there done that but i just want to confirm some info.
74 ohms is empty right
10 ohms is full
well mie ran out of gas the other day i put a couple gallons in measured sending unit....500-800 ohms
put 10 gallons in now it reads 74 ohms? so bad sending unit? i did replaced it 4 years ago it worked for a year then quit now im tired of guessing how much gas i have......if it is the sending unit which company makes a QUALITY product so i don't have to do this again!
p.s rang out the wiring it checked good.
oleguy74
calif city ca
make sure you have a good ground.disconnect plug connector at tank,put ohmmeter right on sender and read.if still reads 74 ohms,bad sender.clean and tighten ground screw at frame at sender.
