EODMike
- Mar 26, 2019
- 180
I recently hooked up my fuel sending unit. Brand new tank and sending unit, but replaced all wiring during rebuild, and used original gauge in instrument cluster with new regulator. When I turn ignition switch to on and when running, gauge reads full. I know for a fact it is not full.
I used the mounting posts for the sending unit as ground. Would this maybe give a bad ground and cause the gauge to read full always?
I would like to start small prior to dropping tank to check positioning of sending unit.
Thank you,
Mike
Thank you,
Mike
