My gauge isn't displaying properly, it shows the tank as empty all the time. But it will rise from 'off' to 'empty' with the key on. If I unplug it from the sending unit, I get no movement. From what I can gather, the fuel gauge is supposed to read empty at ~73ohms, and full around 10ohms. If I stick a meter on the sending unit, it reads about 73ohms, and that's consistent with an empty tank. So, I think the gauge is OK, it's the sending unit. Agreed? I did read a little bit about using a 9v battery on the gauge leads to test for movement.
A little background: I did have to pull the sending unit from the tank to get the tank repaired, but it still worked after that. I'm wondering if I killed it accidentally, or maybe it was just it's time to go. I'd really like to not pull that sending unit as it's a real bear with the tank installed, and it's a real bear to pull the tank. Maybe there's a fix otherwise? Banging on the tank perhaps? %)
