Fuel gauge operating in wrong direction
zfbailey23
So I couldn’t find anything for this particular issue.
My fuel gauge reads 1/2 full when completely empty & off the gauge when full.
I have switched the wires on the fuel gauge- no difference
I dropped the fuel tank and everything is hooked up the way it should be.
I replaced the gauge cluster voltage regulator- nothing
I haven’t replaced the fuel sending unit or the fuel gauge
Any ideas?
NJBronk
Did you measure the ohms of resistance at the sender? (should be 73 ohms empty and 10 ohms full, I think).
Maybe a bad ground as well? That can do weird things....
zfbailey23
zfbailey23
I did make a new ground- on the cluster & the fuel sending unit. So it should be good.
I haven’t measured the ohms as of yet. I’ll try that and post the numbers
m_m70
Prescott AZ
has it worked fine for the last 12 years and now just starting to have issues or is it a 12 year old tank and sender that you are just now installing?
I remember about 10 years ago there were some sending units that were wired backwards. Not the wiring that attaches to them, but the wire wound resistor inside the tank. The sweep went the wrong way on the resistor. Manufacturing flaw.
m_m70
Prescott AZ
So re-reading this.......it's not reading backwards, it's just off and way of at that! If it was backwards, it would read full with no gas and empty with a full tank. So not sure...stuck float maybe but that wouldn't explain the of the gauge when full (assuming it's going of the gauge to the full side).
zfbailey23
zfbailey23
Well, the fuel gauge used to work like that. It would read full when empty & vise versa. Now instead of “F” it reads “1/2” & when it’s full, it reads way past empty.
What’s also strange is the rest of the gauges are off as well. The temp reads zero when at operating temp, the oil pressure gauge reads “10” when it’s been tested from the oil pressure sending unit to be normal operating pressure- around 40ish.
The voltmeter garage simply doesn’t work
And the speedometer doesn’t work anymore either.
zfbailey23
zfbailey23
I had a similar problem with an aftermarket sender, I got one of these and dialed the range in with the module and haven't had a problem since then. I've been running this module for 5 years, trouble free. You'll have to call/email them to order it http://www.marshallinstruments.com/products/9230.cfm
Do you know if this would help with the rest of the gauges being off?
What I’m worried about is that it used to work fine, all the gauges did. The bronco was sitting for a few years, I had the body done and when I got it running again, all the gauges worked but the fuel was working in reverse for some reason but the rest of the gauges worked fine, then all the gauges sh** the bed & started behaving like gaggle of a$$holes.
Bitch'nBronco
Loose Cannon
Ringwood, NJ
Sorry, I missed the part where the rest of your gauges were off as well. I'd start checking grounds, since you mentioned the body was done if it was taken off the frame maybe you've got a bad body to frame or engine ground and its causing all of your gauges to read incorrectly. Do you know anyone else nearby with a bronco that may have a spare cluster you could install to see if its a bad unit?
NJBronk
I made sure to ground the cluster. I ran a separate ground wire to the body
I wouldn't be surprised if the body isn't grounded well... Especially since you said you had body work done (paint?). Maybe run a temporary ground wire straight from the cluster to the negative battery terminal - at least you'll rule it out 100%.
zfbailey23
zfbailey23
So these are the reading I got
This is full 73.6
Empty
Bitch'nBronco
Loose Cannon
Ringwood, NJ
+1, I really think you should validate that your body to frame or engine grounds are good, clean surfaces and tight connections with maybe a little dielectric grease. Any other electronics acting wonky? Maybe radio, CB, etc?
zfbailey23
zfbailey23
I tested the ground with a another source and it was working,
