Fuel gauge sending unit
junebug
Ok so I have replaced two sending units in the past year and it tired of pulling the tank! What could be killing them?!
66 Bronco Dave
You are getting to many volts. 12 volts is to much. I think you need some sort of resistor at least that's I read on a ford forum. 60s to 70s sending units ran low volts through some resister I think in voltage regulator I'll try to get you the article
garberz
Bronco Influencer
Conejo Valley, Ca.
The fuel sending unit only varies the resistance to ground. There's no voltage going to the sending unit. The instrument voltage regulator supplies a 5.5 pulsed voltage to the fuel gauge, and the sending unit supplies the ground. The varying resistance in the ground is what makes the gauge read differently. 10 ohms is full, 72 ohms is empty.
Mark
J
junebug
Thanks mark...unfortunately my electrical system is still an original cut up mess from over lord knows how many owners. I will try one more time lol. Hopefully it's just a cheap part problem.
