deltarat, stay away from holley EFI unless you want to plunk down the dollars for the Holley Commander system. Lot and lots of issues with the holley systems. You could also look at either the Howell EFI system or Turbo city EFI. Personally I have installed three Ford SEFI systems and all of them have worked great. I would suggest that you pony up the money and buy one of the new harness's, Ford or Ryans. Ryan/RJM harness has some good pro's such as having an easy hookup for the Baumanator harness to run an AODE or the easy ability of swapping from a manual to auto computer if needed. You can do this yourself by swapping pins but it's nice to have it this handy. The RJM harness is really really easy to install for the first timer. The Ford harness is really well built as well and is very easy to install too.
As others mentioned the Ford stuff can be had very very cheaply, all of it is usually available locally and you have a wealth of tech help here and other sites on the net. People get very scared by the EFI install and yes it does take some research and reading to gain an understanding. But consider this, how many people really really understand carbs? At this point I know as much if not more about SEFI as I do about all the carbs I have run on other rigs in the past. At OCBR, a buddy wondered around asking people about his wierd carb problem and most everyone said they didn't know much about carbs. I would be willing to bet these same people would likely be afraid to try the SEFI install on their rig.
Dig up the parts and do the Ford SEFI equipment, you won't regret it!
Ben
Ben
