Fuel injection problem?
BRONCITIS74
BRONCITIS74
Wow. A lot of information. I will start checking all these things. Thanks, guys,
Mike
Steve83
Yes, Ford dielectric grease is for heat transfer between an ICM & its heat sink. No, that's not likely the cause since I've driven on an ICM not mounted to any heat sink.
The correct diagnosis is to follow the (LOOOOOOONG) procedure on this page (bottom half, but read the top half first, which is also LONG):
(click this text)
For it to be a MAF engine, it must be '94-96, which also makes it CCD. But it would be better if you posted LOTS of pics, including some showing the color of the middle wire in the ICM connector.
Maybe yours was a high-quality original. Many other stories of quick failures when thermal compound was not used.
Maybe simply the difference between quality, OE parts, and cheap imported aftermarket parts. Or just bad luck with the others…
I thought, at least as far as the Mustangs were concerned, all 86 to 93 EFI 5.0 engines were mass air.
Ford continued to use speed density on other vehicles, but I thought the Mustangs always had the MAF. Is that not the case?
Sorry I didn’t read the text in this case like I usually do.
blade
Maker of sharp things
Santa Fe
86 - 88 mustangs were speed density.
bronco italiano
I'm think TFI also and possibly the ECM caps as previously stated. EFIGUY said the ECM needs to be serviced every 5 years. My ecm was just starting to have problems (6 years old) with the caps when I sent it for servicing.
rocknhorse76
Bronco owner since 1993 💪🏻
Central WA
The TFI module is what I’m leaning towards if it is an ignition issue. Before I switched to EDIS, I would have issues with the distributor-mounted TFI failing when the engine and/or ambient temps were high. Only after finally replacing the cheap aftermarket modules with an OEM module and plenty of high quality heat sink paste, was I able to keep it running consistently when it was hot out.
Timmy390
Conway, AR
Didn't Ford go to remote TFI in the SN95 stuff? I know that 96 E350 vans were remote. I'm running a van harness modified to SN95 EFI and have remote TFI.
I mention this as I recall reading about how to wire up a remote TFI for the 89-93 mustangs.
Tim
rocknhorse76
Central WA
Tim
Tim
Yeah I guess we need him to post a pic of the distributor 👍🏻
rocknhorse76
Central WA
I have a 74 Bronco that has been converted to a 5.0 efi motor. I think the motor is from '93 or '94. It has a single stock rear gas tank. The fuel line , the fuel pump (in line, mounted on the frame) and the fuel filter have all been replaced. The rotor and spark plug wires are only 2 years old. The truck runs fine till the outside temp gets into the 90's. Then, every once in a while, the motor stutters, then kills. If I let it sit for a few minutes, it starts and runs fairly good. I talked to a guy at the Wisconsin Super Celebration and he told me he had the same problem. I took his advice and replaced the stock radiator with a 4-core radiator and added a 6 blade fan, and added a new shroud. It runs at about 165 deg on the hiway, but gets to 180 in town. That still isn't that hot, but it still kills. Have any of you guys had the problem or know how to remedy it? Any help would really be appreciated. Thanks.
Can you post pics of the engine so we can determine what year the EFI system is? 94-95 are a slightly different system. Also, your coolant temps are too low for a factory EFI setup. Newer vehicles run hotter than old carbureted rigs. Most of us with EFI use a 195* thermostat with a good radiator and fan/shroud setup.
Tim
Yes they did. The SN95 also went to computer controlled dwell where the trucks stayed with TFI controlled dwell long after they went to remote TFI. I don't remember if the last year or two were still TFI controlled dwell. The factory color coding was black for computer controlled dwell and gray for TFI controlled dwell. Learned a bunch of this stuff when playing with a stroked in a Ranger. The remote distributor is also shorter, to the point it can interfere with Explorer fuel rails. Mix and match parts. Remote TFI and pickup inside of an integral TFI distributor housing.
There is a trick hot ignition for points using the truck (TFI controlled dwell, gray module). Popular on older Honda motorcycles with very weak ignition systems. I did it to my boat that is running a mallory marine distributor. I can say that it is a wicked spark when it fires.
Also correct on early fox body HO were speed density. '88 California got mass air a year before the rest of the country. Trucks stayed speed density for several more years but went mass air before the small block was phased out. I think California got that first as well.
Usually when you bought a new TFI or distributor there was a little capsule of the heat transfer grease. I've always found it to be a very different consistency than the dielectric grease used to keep the spark plug boots from sticking to the spark plugs.
73azbronco
First rule of EFI troubleshooting, what is your fuel pressure and volume?
Piling on, 165 is just right out, the efi computer is not even going closed loop until it gets warm at about 185. You need a 195 degree thermostat for ford efi applications, maybe 200.
Speed density or mass airflow?
Original efi wiring to computer, injectors sensors, etc? That could be an issue when warm.
Using EVAP system from factory, solenoids for EVAP canistor?
Idle vacuum cold and when it acts up? Intake leak when warm?
Steve83
...as far as the Mustangs were concerned...
I must have missed where he mentioned the engine being from a Mustang. I always have truck engines on the brain, so that's what my comment presumes. If he's using Mustang wiring, he should ignore my previous post.
I don’t think the application was actually mentioned. Or if it was, I don’t remember.
I was just going by the fact that most bronco donors back in the day were out of mustangs and other passenger cars.
Probably due to being just as prevalent, but with lower profile induction systems. So I was assuming a little, and still asking for details and clarification.
JSBX
If this is a mustang EFI there is a lot of good information on the Fox body Mustang forums. I bought a 69 Bronco with Mustang EFI and knew nothing about EFI. I have learned a ton by researching on these forums. Learned how to test different ignition components, fuel injectors and other EFI components. You can find answers to most any question that you can think of. If it winds up being a bad TFI module McCully Racing Motors sells a TFI module relocation kit that lets you move it from the distributor to somewhere in the engine compartment that is not as hot.
36Fan
Start with the fuel pump and pressures at the rail.
bmc69
Y
We use a lot of both dielectric grease and thermal transfer paste in our marine electronics products and, yep, the consistencies and colors are quite different. ;-)
BRONCITIS74
BRONCITIS74
After contacting the previous owner, I found out that the motor is a stern drive '93 Omc speed density motor. Does this help you guys determine my problem?
Yes and no. Without some actual pictures of the installation, including underneath at the fuel pump, we're still just guessing.
In other words, we'd still like to know if it's a proper installation in all aspects. And was it and the wiring "hacked" together, or was it done cleanly. Including where the pump is mounted and what kind of distributor it has. You said you'd check on those things, but I don't remember seeing if you responded to the individual questions.
Regarding the induction, you said MAF initially, but the PO (previous owner) says SD. But since the engines can be converted, we'd still like to know what you have. Is it still Speed Density using all the original Marine stuff, including the computer, or was it converted to MAF use when installed in the Bronco.
I realize you won't know, or might not know, much of that stuff just off the top of your head. Which is why more details including pictures would be most welcome.
We know heat can effect several items, including sensors and fuel pumps and relays and computers, but we don't know how all of those items were installed yet.
Hence the additional requests for pics for us to check out.
You can't post images directly to the discussion unless you become a contributor for 12 bucks a year. But you can post them up into your "gallery" and "garage" features, or e-mail them to one of us with the word "contributor" in yellow beneath our usernames.
There is even a way to send pics via private messaging, but frankly I don't know how that's done. But probably need to be a contributor for that as well.
