Fuel Injectors?
WyleCoyote
Ok, so I have the Lincoln 5.0...Injectors are all questionable...
I need to replace them, so should I go with the 15lb injectors that were stock, or should I go with 19lb injectors? will it screw up the computer if I go to the 19lb injectors? It is MAF.
believe it or not, the 19lb injectors are cheaper and easier to find.
Injectors must match what the computer is programmed for. What computer are you going to be running?
WyleCoyote
WyleCoyote
I have the computer that came with the car, it's not one of the normal ones mentioned on here. I'll have to get the digits off it later.
WyleCoyote
WyleCoyote
Darn. Ok, looks like that is the route I'll go. Anyone have a line on the best(Cheapest) place to get new injectors?
ransil
Might be cheaper to send your to Mr. injector to get them cleaned and tested.
I get them from the junkyard.
WyleCoyote
WyleCoyote
Can they fix the one that broke when I pulled it from the manifold?
WyleCoyote
WyleCoyote
Cool, thanks guys, I broke the nose piece that sticks into the manifold. I was stuck in there, had to chip the plastic part out. I did find a full set on Ebay for $86, I might go that route.
eds66bronco
Essex, Vermont
I used this guy... http://www.witchhunter.com/
way cheaper than buying new. He got all mine to flow better than factory spec., had quick turnaround too. I'd just grab a replacement at the junk yard and send them off to be cleaned. you may find the e-bay set has a stuck injector and then you'd still be in the same boat.
WyleCoyote
WyleCoyote
You know what is cool about that, I'm close by to Bothell, WA! Figures it would take a Bronco Brother in Vermont to find me a local shop..
msweb
Old thread so hopefully not a hijack... Since it was recommended that they were sent off to be cleaned, is there not a way one could do it themselves? Only reason I ask is because I was trying to figure out how to clean mine before putting everything back together...
Randrew
Tempe, AZ
I haven't done it personally, but a buddy of mine bought the rebuild stuff from rjminjectiontech.com and followed this writeup. I don't think he used an ultrasonic cleaner. Maybe he just soaked them instead. Either way, he said it worked out fine. There's also a brief writeup here. You might also buy an injector pigtail so you can make a test harness to open up the injector.
msweb
Wow, so much for using compressed air and a bottle brush but then again, it isn't a jet from a Holley, is it! Thanks for the links!
HoosierDaddy
I cleaned mine using the RJM instructions , kinda , my soak lasted a long time till I could get back to finish them.
No problems so far .... luckily I had the old chopped harness and had all 8 pigtails. Only one is needed .....
If I have extras , I could mail you one .....
msweb
What did you soak them in? I actually have 2 sets of 19lb injectors and harnesses to use but I do appreciate the offer!
I built my own tester / cleaner.
I saw that, pretty impressive but way over my head. If I decide to go ahead and clean/rebuild them I'm hoping this will be a one time shot. I may just soak them and go from there, I dunno yet. I'm working around Anthony's schedule here and I don't want to be in the middle of something when he needs it for the next step.
I do like the idea of rebuilding them if nothing else for the challenge. The EFI swap that scared me earlier is becoming something that I'm picking up faster than I thought and I'm actually enjoying learning about it! ;D
