stingus
So I picked up my Bronco today from my mechanic, new electric fuel pump, new fuel lines. The new fuel pump is mounted on the frame towards the front of the engine. My mechanic also dropped the tank and said the filter was not clogged. Drove great for about 45 minutes, then all of the sudden it bogged down till I had no power again and barely coasted off the side of the road. Turn the key and i hear the pump running so I'm assuming its pumping ok. Waited 5 minutes, cranked it up, got to the Auto parts store. Looked at the fuel filter I installed 2 weeks ago, and it had lots of debris inside. Replaced the filter and it ran pretty good for the 20 minutes it took to get home. Got it home safely.
Left it running, looked under the hood, revved it up, had a good constant fuel level in the filter. I don't think it is an ignition problem b/c it is bogging down and not just cutting off. Do i need a new fuel tank? Would the debris in the filter be enough to cause the engine to bog down all of a sudden while going 60 mph? The fuel lines are running against the frame and don't seem to be too close to the manifold so I wouldn't think the lines are getting too hot.
More help and suggestions would really be appreciated.
Thanks!
Ben
Thanks!
Ben
