Fuel Return for standard tank with EFI
russhow73
Austin
I've got a 5.0 I've got running. I need a new fuel tank and don't have the cash for a $600 23 gal efi model. I plan on buying the package from toms with the tank, sending unit, etc. for $250.
Any good recommendations on how to run my fuel return line?
Simple and reliable is my goal.
Please keep in mind the Bronco will only be a weekend driver for my family, not much off roading at this point.
Thanks,
russ:)
SC74
I have not personally done it, but have heard that one of the easiest ways is to route it back into the filler neck. Weld a fitting onto the neck and make it thread in for a good seal. But... since you are starting with a new tank and not full of fuel, you could do the same into the top of the tank.
Scoop
Bronco Old Fart
Cuchara, CO
Just tie into one of the vent lines - easier than tying into the fill line. I'm running the stock size plastic aftermarket tank which has 2 bungs for 1/2" vent lines. I just tied into one of these. Works great. Just need a T and 3 hose fittings.
Greg_B
Cohutta, GA
X3 on what is said above. I ran the stock tanks for many years with EFI. I soldered a copper tube in the filler neck for my return line. I had a T in it for years but kept having issues with fuel vapor condinsating in the charcoal canister so I tried all sorts of different methods of running lines. Nothing corrected the vapor issue... not even a 23 gallon EFI tank.
It only stopped when I reinstalled the canister purge solenoid and vented the canister to the intake like it was designed to be hooked up.
All is well now... but you should be fine with a T or a line into the filler neck. No need for anything special.
Greg
KyleQ
I just added a return line into my fuel filler neck - very easy. I even used ghetto parts and it was CHEAP! I got two 45* 1/8" blocks and a package of lampshade extender thread (it's NPT like the 45* blocks I got). I drilled a hole through the filler neck, tightened the pipe into the block, ran a wire through it and tied a knot on the end. I fed the wire through the hole, pulled the fitting and pipe through the hole, put some RTV around the hole, drove down a jamb nut and tightened the outer 45* on with a wrench through the filler hole. Nothing to leak as the fluid is going through fittings, the RTV is there just to keep a good seal - contaminate free.
Nothing to leak as the fittings are rated for what I'm doing with them - clamp 3/8" fuel line on the threads with an EFI clamp and the fuel just sprays down the filler neck, easy as pie.
Nice to see the color of the fuel and how good it is flowing. This was done for under $5 :cool:
Note - I WAS going to go the EVAP route, but you cannot get to the fittings without dropping the tank and my lines were quite rusted. I didn't trust them to carry fuel vapor, let alone pressurized fuel. Not to mention I'm scrambling to finish, avoid spending lots of money and everything is fawking covered in mud..
blazinchuck
why not use one of the vent lines on tom's tank?if you get off-camber on the driver side while running...i think it may try to fill the neck right behind the gas cap...might seep gas
Greg_B
Cohutta, GA
Why would that matter? It wouldnt be any different that the stock setup unless I am missing something... which I do a lot by the way... :cool:
Greg
KyleQ
It's spraying down with decent pressure, but yeah, with a full tank mine seeps gas too - it lets me know I'm flexing quite a bit :p
blazinchuck
Greg
well, stock didnt run a return or have a return to the filler neck. and yes, even stock can seep gas while off camber...maybe due to the fuel overflow line has a kink or something.
i was more concerned bout extra fuel filling in the neck while off camber. most if not all after market tanks will have 1 supply,2 vents(whick one vent line can be used as a return)
kyle, is your return below your stock overflow line?
KyleQ
It's close - if not equal. It does spray fuel down the filler tube though..
blazinchuck
i guess just try it and see...how much pressure is coming out? ive never checked my return(its at the tank)
btw, good job getting some cheap efi
KyleQ
Not enough pressure to make it spray harder like a garden hose, but there is a little there. That is at idle, I imagine at more throttle there will be less fuel.
browngr5
Eagle, Idaho
Thanks,
russ:)
No worries. Just install a brass T fitting in the rubber breather hose above the rear leaf shackle. It works fine. Install inline HP pump above frame behind fuel selector. Run fuel selector output to HP pump input then high pressure output to motor.
If you want to use your aux tank just flip the fuel selector while driving and the return line will fill the rear tank. Watch your fuel level so you don't overflow the rear tank. Switch it back after fuel transfer. I installed inline fuel filters at each tank. I have dual exhaust so I built a shield on the frame to block heat for the HP pump. This setup works for me, I may never change it unless I have money to burn.
browngr5
Eagle, Idaho
I don't want to offend anyone using the accumilator...Just saying I think it's leaky vapor locking, ugly, piece of expensive crap....Just me though. Please don't be offended just my rant. It probly works better for most other people.
