Fuel Sending Unit Ohms?
Ripcity
Coos Bay, OR
Is the Bronco fuel sending unit 70 Ohms empty and 10 ohms full? I am looking to put in after market fuel gauge. Is it as easy as hooking the two wires from the sending unit to the gauge?
Thanks!
oleguy74
calif city ca
yes...73 ohms empty...10 ohms full.the 70 ohms is close enough.your new fuel gauge needs to be ford type.10-73 ohm range.
sigepkat
Mine's reading 6 ohms at the sender, is that why my Autometer gauge is reading well past full?
Steve83
No. One (either) of the gauge terminals goes to a switched 6VDC source (or an IVR from a switched 12VDC source); the other goes to the sender. The sender's other terminal goes to chassis ground.
Yes.
travisman
No. One (either) of the gauge terminals goes to a switched 6VDC source (or an IVR from a switched 12VDC source); the other goes to the sender. The sender's other terminal goes to chassis ground.Yes.
Does it all applies to all model of ford fuel sending unit? My friend is asking me about this, but i am not sure for the info i will tell to him.
