This is for a NWMP aux tank and a new WH sending unit for the same, and the sending unit float arm can be adjusted as a sliding arm on the pivot point, so if the float is adjusted to be at or nearest to the top of the tank at full, it would then physically rest on the tank bottom at empty, or I can adjust the float arm to be just above the tank floor at empty, but then it will be about 1" below the liquid line when full.
I don't think I want it banging around the bottom of the tank at empty, but also, have to believe that if the float is submerged while at a full tank for any period of time, it will eventually fill with fuel and be useless.
Any thoughts on what the better adjustment setting may be?
Thanks as always.
Thanks as always.
