I've decided to remove my auxiliary tank and just go with the rear 23 gallon NWMP tank that the p.o. put in because I don't so a lot of long distance or off-road driving.
I dropped the rear tank and basically it's 99% clean, not sure if it was ever used.
My question is, do I need to seal it once I clean it thoroughly?
KBS and Red Cote are kinda pricy but would it be foolish not to seal it seeing I already dropped the tank?
If you all recommend sealing it then my next question would be how do you get the sealant around the baffle/inner wall of the tank to make sure everything on the other side is coated?
Thanks for any responses...
