Fuel tank selector switch
WPS 73 Bronco
The Woodlands, Tx
The prior owner installed the electric tank selector valve, but plumbed it wrong. The main gas tank is plumbed into the aux inlet. i Recently replaced my fuel selector switch to see if that was the issue with the gauge, and it was.
Now my problem is the fuel gauge and tank selection is not in sync. I really don’t want to replumb the fuel selector valve to get them in sync.
Can I change the connections on the back of the new selector switch to get the gauge reading the wrong tank? Per the attached drawing, I just swap the red and blue connector, but nothing changed.
Any ideas?
Yes.
Simple solenoid selector? In the diagram above the top row of 3 wires appears to be for the gauge.
The bottom row of 3 connectors. You should have one wire connected to the center terminal and one to the bottom left or right terminal. Just swap sides (left to right, or right to left).
WPS 73 Bronco
WPS 73 Bronco
The Woodlands, Tx
Will this also correct the toggle switch alignment?
Meaning regardless of the plumbing being backwards, the solenoid will now be in line with the switch (left is main)?
WPS 73 Bronco
WPS 73 Bronco
The Woodlands, Tx
So I'm confused. Two of you are saying swap the bottom connections which are tied to the solenoid valve. Oldtimer says swap the red & black which is tied to the gauge.
If I swap the bottom, I was assuming it changes the solenoid valve to be "tricked" on my switch. Before I make the change, with the switch set to Aux, its really the Main tank. After the switch, Aux is Aux & Main is Main.
So do I do both swaps?
Oldtimer
Jr. Member with Sr. moments
Sunnyvale, CA
My comment is based on:
You should have swapped red & black, NOT red & blue. Then gage & tank source would aggree.
If originally the gage displayed agreed with switch position, then yes I would swap the outer connections on the LOWER row on the switch.
Then gage, source, and switch position should all agree.
NOTE: I do not know how this selector valve works, but I ran into a situation
where the selector valve needed power to stay in the aux position. The PO wired the power source from a ignition switch contact that had power in run, but not in crank.
Main tank empty, Aux tank full, when cranking engine to start no power to valve caused pump to suck from main (empty) tank, and engine would not start.
