You do realize the tanks need some venting in order for fuel to be pumped out of them, right?
This is one of those wheels that really doesn't need to be re-invented. Use the stock system or make one like it.
This is my first carb'd/mech pump vehicle and first time working on a fuel system. Spent Friday looking at all of the setups on the Barrett Jackson Broncos. Also stopped by Driven Auto Parts in Phx. They told me to cap the vent lines and put a pinhole in the filler neck to vent the tank. Probably an offroading type of mod, not something I want to do.
I have the vapor canister but no charcoal canister, yet. Im gonna stop by a junkyard to pick one up. I have spent too much time on this aux tank install already, so I want to do it right and be done with it. If I mount the charcoal canister higher than the fuel lines, I can eliminate the vapor canister? If I mount the canister on the frame, I would have to run the vapor canister to keep fuel out of the charcoal canister? No plans to go EFI. I want to be able to completely fill both 12 gallon tanks and not smell fuel
I have 4 lines that I need to run(2 on each tank). Can all 4 go to a charcoal canister? Seems most canisters only have 2 ports from what Ive seen. Run a Y connector before the canister? Or could the return lines be run between the tanks and only run the vent lines to a charcoal canister? I think I have this figured out but let me know! Thanks
Any benefit to running a vented cap if doing any of the above? Would it change anything?
