read quite a few post about the subject, gas smell outside the vehicle, raw gas running into vent line, charcoal canister, expansion tank ect ect. and had an idea and was wondering if its a bad idea or not and wanted some opinions.
my plan is drill a hole into the top of the fuel filler pipe as close and as high as possible (just behind quarter panel) and weld on a nipple of some sort and attach a hose/tubing to it and run that down the fuel filler pipe along the frame into a charcoal canister under ther hood, plug the vent on the fuel tank (not filler vent tube)
*by installing on top of the fuel filler pipe this would prevent raw fuel from getting in the line (unless u fill the tank extrememly full)
*the fuel filler pipe would server as the expansion tank.
does this seem a descent solution to some problems i've read?
