Fule tank sending unit question?
Bronco Sport
NW Portland, Oregon
What tool do you use to get the sending unit out of the tank? I understand that it's a threaded crown ype, but what's the easyiest way to get it loose?
Ron Morris
1968 Bronco Sport
stevew
Elliston Montana
To simply describe it , a "compression" ring holds it in . Take a punch or screw driver & drive the ring counter clock wise to release the "ears" . The ring will fall out then just pull the sending unit out too . Theres a large O ring seal behing it thats fun to put back in . :p
broncnaz
I've used a screwdriver and a hammer to tap the inner locking ring around until it unlocks then just remove the sending unit
Bronco Sport
Bronco Sport
NW Portland, Oregon
Great I will give it a try.
One more question, has anyone had much luck repairing their sending units, or do you just replace them? Both of my tanks units have died after it sat for a winter.
Jeepster
[quote author=bronco Sport link=board=5;threadid=22154;start=0#msg170997 date=1063752316]
Thanks, I did take a look at that, but wondered if anyone had much luck or what the sucsess was. :D
[/quote]
the units dont just "die"...well you know...... chances are the contact arm just lost connection due to sitting/oxidation on the arm that makes contact with the windings.
