Billsboat
My 71 cut out on me yesterday. It sputterd a bit and died. Started back up and died shortly after, would not start again. I saw fule going into carb so I assumed that was not the issue. Replaced plus, points, condenser, coil. Still would not start. Rechecked fuel flow. Nothing going into carb. Switch from main to aux, and fuel started flowing, and it started and runs fine. Switched back to main tank while running, and after about five min it stalled. Went back to aux tank started up, runs fine.
So here's the question. The fule tank selector switch "clicks" when I assume the switch is in the proper position. Is it possible that because the switch is old the "click" I'm hearing is no longer lined up with fule port.
So what I'm trying to deside where to start replaceing parts.
Thanks for any input!
