full floater rear brake options
eds66bronco
Essex, Vermont
what are the options out there when using the full floater kit (WARN) for rear brakes. i've searched and can't find anyone that offers the disk brake kit for this application although i saw the warn site mentioned it is not compatable with other mfg's disk brake kits. i keep thinking that it should not be so hard to do a home brew full floater with all the spare parts i've got (dana 44 spindles/hubs, have some full size axles cut/splined) any thoughts along this line for the 9? although mike sells the warn kit for $799 but i'd still need brakes.
http://www.earlycj5.com/tech/axle/d44FFDIY/index.shtml
eds66bronco
eds66bronco
Essex, Vermont
found the following on the warn site:
1976-1977 Disc Brake Brackets
BRONCO (For Warn Full Float Axles; Ford 9 in. Axle;)
37765
Uses Modified 82-86 Jeep CJ-7 Front Rotor ; Rear Disc Rotor Not Modified
WARN Disc Brake Brackets Only Work With WARN Floating Axle Kits
WARN Disk Brake Brackets Designed To Work With GM Metric; Cadillac Calipers
Not A Conversion Kit; Requires Extra Parts; Rotor And Calipers
will the disk rotors and calipers bcbroncos sells in their kit work for this application? (not sure what gm metric means) i already bought the calipers knowing i was going with chuck's kit in the future (had to use up some credit i had at the parts store)
crawln68
I would put a call into Chuck. He is always willing to help with anything that I've ever called him about. Let us know what you find out.
lars
Been here awhile
NorCal flatlands
37765
GM metric specification includes the Caddy calipers. There's also a front caliper without the e-brake mechanism that's the same size. Found on certain Monte Carlos, I believe.
That's the same rotor used in BC Broncos' kit, though BCB requires that the rotor be modified (center hole opened up) to fit a stock EB axle. Since Warn specifies "unmodified" you can just go to a local parts store for them. I bought mine at NAPA a few years ago for about 25 bucks each. I don't have the Warn kit- I have the BCB setup- but because I have Moser axles the rotor mod wasn't needed.
SaddleUp
Vancouver, WA
I use to see full float axles put on H**ps this way long before Warn started selling them. The biggest issue will be to get the axle flange to mate up to the spindle. Once that was done then you would be open to any disk brake used on the front but you would need to figure out the ebrake. Either by changing the caliper or by using a driveline ebrake. If you can figure out the mating of the spindle/axle then you can probably build a mount to fit a caliper with an ebrake in it without too much more effort. (In the kits you pay for that bracket and for them to collect all of the other parts)
eds66bronco
eds66bronco
Essex, Vermont
after looking at the price of a set of custom axles made to fit and the cost of a set of hubs/rotors/spindles and machining of parts, looks like the warn kit isn't as far off base as i thought. i just like the thought of homebrew solutions that don't involve the CFO (wife) %)
toddz69
Chuck told me a few months ago that his brake setup works with the FF kit. I think he has the full floater on the back of his truck, but I can't remember for sure. With some minor machining, the 75-79 Lincoln Mark V discs work with the Warn kit too. I ran that setup for years.
Todd Z.
