Weatherman
Track bar riser ordered from Ruff Stuff Thanks quikdrummer !!!
Awesome thanks !! What axles did you use ? Do you have a wright up somewhere ?
That would move your coil over and get it better lines up with the upper bucket but you have to make sure you get a good weld there. Grind it way down and get a good groove to fill with weld. Or maybe you could have some more of them blocks made that are longer and move your coil over. It don't look like it would be to hard to make.
Also I think the U bolt on the upper coil bucket will help you out a lot too. I have the same coil as you so I know how soft they are. Even after getting my lower coil bucket as streight as I could my coils still bowed a little bit and the U bolt put them right where they needed to be.
EffectiveI would consider mounting the other end too the axle itself....better to be too strong than not strong enough....
1966,351w,m5od,205....3.5" lift, 2" body, 37/13/15 boggers
I second mounting it to the axle. If you don't want to weld it to the axle weld a spacer on the bottom so it rests right on the axle. My buddy had a setup just like yours installed by a shady shop that failed and I changed it for him to a setup close to Ahansen's setup.
Looks tons better and beefier too. Btw that a bada$$ looking bronco.
Nicely done
