jonmelton
- May 24, 2012
- 270
Yesterday after adjusting my alignment, I lowered my Bronco off the jacks and got the fuel sloshing around in the tank and then noticed it started dripping out of the main tank. I lit a match and got close so I could see what was going on (kidding) but I noticed it was coming from two places on the tank.
This weekend I'm going to empty the main tank and check it, but I'm wondering what else I should be checking while I'm under there and what I should just plan to replace. My plan right now is to check all hoses and possibly pull the sending unit. I also want to check the evap lines and the charcoal canister. I'm worried about pulling my tank because I'm sure it's the original and I think it's rusted on there pretty good (and I don't want to use a torch to heat up the metal).
It's a 75, the gas gauge on the dash doesn't work so there have been a handful of times where the truck has run out of gas and I've had to put fuel in the carb and switch tanks to get it going again (so I know I've done some damage to some of the fuel components there). Every time I fill up my Aux tank it leaks when the gas runs into the overflow canister so I need to also fix that.
So yeah, anything I should add to my list? Common problems to check for?
