What year is your Bronco & what caps have you tried? Earlier ones use a cap that allows air in to fill the space as fuel is pumped out. On later trucks the air is provided thru the vapor recovery system. If you are using later caps on an earlier truck, or on a truck that has had its vapor system capped off/plugged, it will cause a vacuum in the tank.
