ZookBronc
I am trying to hook up the lighting in my autometer gauges and trying to figure out what to connect the power wire to so they turn on with the headlights.
Blue wire with red strip or red wire with blue strip?
Is there an easy access point by the cluster?
Is there a diagram other than seabiscuits that you can direct me to?
FYI, its a 71 if that makes a difference.
Thanks for you help.
Blue wire w/ white strip i think this is for like if you have a dome light when you turn the headlight switch CCW it will activate this wire, i believe
Thick brown wire with a square connector sounds like that is for the heater controls if i am remembering right...
Purple wire and red sire w/ yellow strip i think that goes to the brake warning light?? i believe that is also for the brake warning light.
so if i'm hooking tachometer lights up to my cluster lights so they will turn on with the cluster lights will I splice it in with that same wire?
Correct.
If i need a power source for my aftermarket autometer fuel guage, what should I tap into? Can I use the radio power lead or cigar lead that I am not using or whats the best way?
Can I split the orange fuel tank sending wire and have one go to the stock guage and the other go to my autometer? Will this screw anything up?
