Gauges and dash
mini73
I'm wanting to add more gauges soon. Thinking of a 5" auto meter speedometer and 5"auto meter tach and auto meter fuel, oil, volt meter, water temp and trans temp gauges. I have the factory gauge in there now. If I get the 5" auto meter speedometer do yall think it will fit where the factory on is? I'm thinking the factory gauge is bigger but not sure. Want to make new holes in the original dash to the right of the steering wheel for the others to go in. I know I could go with a blank dash and place the things where I want but the blank dashs are kind of pricey and I really don't know how to get the old dash out to do it. Is hard to get the dash out and do this? Anyone recommend me cutting the holes while the old dash is in the truck still?
mini73
mini73
I'm wanting to do something like what is in the pic but with a 5" speedometer and 5" tach. How would I go about making holes in the dash?
jw0747
San Antonio, TX
Hole saws...
http://www.homedepot.com/b/Tools-Ha...-Bits-Hole-Saws-Arbors-Hole-Saws/N-5yc1vZc268
If you've never done it good luck. There's a ton of wires and other important do-dads behind your dash that you don't want to destroy. Building a dash requires careful planning and measuring because you can't undrill a hole. You're still going to have a big hole where the factory gauges were if you take the cluster out. As opposed to maybe wrecking your good dash consider adding a gauge panel to the bottom of your dash like a three holer that you can get at most any auto parts store or Jeg's or Summit and install whatever gauges you want in it.
mini73
mini73
Hole saws...
I already have 2 below my dash now. Want to get some auto meter gauges and put them in the dash. If I plan on the hole with my dash and while still in the bronco I will remove everything from behind where I will make the hole. I'm thinking with since the 5" auto meter is somewhat smaller I can fabricate some kind of plate to keep it going through the original speedometer hole.
JoeB458
Springfield
I am working toward a similar setup. I used a hole saw to cut the hole for gauges. Lowes or Home Depot have them. Just be sure they are for metal.
mini73
mini73
I got hole saws at work as I work in maintenance. just got to figure out what gauges I want to go with and what size. Also wondering if I should go with electric or keep them mechanical
DuctTape
Bozeman, MT
I'm currently in the middle of mocking up gauges installed into wildhorses under dash cubby. Might be an option for you.
DuctTape
Bozeman, MT
Take the dash out, not hard once you figure it out.
There are two bolts that hold the steering column to dash. Your column setup my vary but drop those bolts, remove the column support thing on firewall, disconnect the rag or ujoint, unhook yo the electrical and column comes right out.
Disconnect gauges and switches (if you get stuck on ignition switch come back here).
The dash has two bolts that also hold your windshield up, two bolts on the sides (tabs), and possibly two more at the bottom edges on either side (I had a PO that welded these on...).
I think you will find you save time in the long run pulling the dash. If you did that you could config it however you like, patch anything you want, drop a fresh coat of paint on it and voila.
If you don't want to spend that much time then I think you are better off adding some gauges to the bottom of the existing dash.
Digger556
Just my $0.02, but in my case a full set of Autometer gauges costs more than the Dakota Digital setup and I still didn't have turn signals, check engine, high beam indicator etc. In addition, a full set of Autometers was going to be cluttered looking with my dash.
I waited for the DD set to go on sale and saved money over the Autometer.
WorkerBee
Northern CA
X2 on taking the dash out. It's really not that hard once you have the windshield dropped.
I made my own dash but if I didn't have the resources to do so I would have bought a blank one. I had a great experience buying gauges from Speedhut and I am really happy with them so far. They can customize just about anything you want. They're a little spendy but worth it in my opinion. They're very shallow and easy to install.
One other benefit is that the speedo is run off of GPS so there's no more cable. I was planning on doing a full write up on the gauges but didn't want to speak to soon. I wanted to give them a little more time to make sure they're reliable. So far so good though.
http://www.speedhut.com/
mini73
mini73
I don't have no problem with letting the windshield down has I have no top and no dash pad. I do have a full roll cage but the way it ended up when I installed it, it's not that close to the dash so I might be able to get it out. Never thought about the gauges you are talking about. Interesting. But I can not see the pics you posted
markw
Ron, that's a great layout! I'd love to pay you for a copy, it looks like a lot of thought and work went in to that layout. Mark
RonJones
BoureeOne
Madisonville, La
My route is a little unique. I am using 1948 Lincoln Continental gauges. I also found a 1948 dash, and modded it to fit into my dash. I also picked up an extra clock that is going to be converted into a tach.
