blainebrazil
I am in the process of swapping out an edelbrock gear drive from my 76 with 302. I have the timing chain i pulled out 20 years ago that virtually had no miles on it. Its cast iron melling 3-358sa. The cam gear from the gear drive set had a brass thrust washer behind it. Does the cast iron cam gear require a brass washer as well? Also the timing cover has been modified and the angled casting on the inside had been ground off to accommodate the idler gears. Does this casting serve a purpose? Or can i install the timing chain without it or do i need to purchase a new timing cover?
