Gear experts - pattern opinion.
Devin
Bronco Kineticist
Well, I am closing in on getting my 9" build done. I am pretty happy with this pattern, but am going to try one more adjustment to see if I can get it centered a bit better. Plus, the coast side looks a bit strange - maybe I didn't load it up enough while I was generating the pattern in that direction.
But, I am done for the day, so I figured that I would submit some pics and see if everybody else thinks that this pattern is looking ok. B/L is ~.008.
Thanks for the opinions.
jabranovich
New Castle PA.
pattern
Thats what I do all day,pretty good ,To move drive side in towards center and coast "out",take another .003 out of shim and you should be "dead nuts" right on,you need a job?
4x4man514
Augusta,Georgia
im no expert but ive set up a few also. that looks plenty good. ive seen the coast do funny stuff several times. i was told if your drive looks good not to sweat the coast too hard.
Devin
Devin
Bronco Kineticist
whats the thickness of the shims under the pinion support?
In that picture, it was .025".
I sold my original axle and started with all brand new parts, so I didn't have a good "starting point". So, I started with .035", and the pattern indicated that the pinion was too far out. I next tried .028", and it looked a lot better. Then I went to .025" (shown). With each iteration, I kept the B/L hovering around the .008 - .009 mark.
Once I get another chance to hit the garage, I am going to try .022" to see what it does. I'm in no hurry and it is kind of fun seeing what messing with the shims does to the pattern. ;D
Thanks for the replies, it is appreciated.
rednck21
just what i thought;D ive built a few with no starting point and from what ive found about .018-.020" is a good starting point. so yes i would take about .003-.005" out and see how it looks;)
also, another thing to look at is the contact(paint) on the pinion. you can tell alot by those marks, too.
