[quote author=xbanone link=board=5;threadid=14405;start=0#108401 date=1045534304]
The blue wire goes to one side of the ballest resistor then to the ignition box, the purple start wire goes directly into the ignition box, the white wire goes to the other side of the box then into the + side of the coil, is this how it's supposed to be? The accel FAQ section of thier website says i need to use the stock ballest resistor with thier coil, does the resistor supplied in the kit equal the resistance of the stock resistor? I know the stock harness used a "resistor wire" what is the difference between that and the ballest (if any? ) ??
[/quote]
Have you looked at page 15 of the instructions? As I look at it here is what I have for Duraspark install in relation to the 3 wire connector(they call engine harness):
blue--goes to the ballast resistor, then from that same terminal(not the other side of the ballast resistor) it mates with the stock harness in the 2 pin connector** with the wire that is red/white).
violet--goes directly to the 2 pin connector** with the wire that is light blue.
**the instructions call this connector the "distributor plug"
white--goes to the free terminal on the ballast resistor, NOT the one that the blue should be attached to, and from there it goes to the positive side of the "Ford coil connector"...I assume this could also be substituted for the positive coil terminal
*note: there are seperate violet and white wires that are for the solenoid connections.
*also I noticed you said your white wire went to the other side of the box, then to the positive side of the coil...other side of the box? maybe the problem is there?
I hope this helps some, however Centech is really helpful if you haven't already called them.
John
