Does my glove box latch and striker look to be installed correctly? It doesn’t latch. The dash was installed by a non- Bronco specific shop and I am going over all of their work.
And have you manipulated the latch manually, going through the open/close motions by hand? Maybe it's stuck, or is actually in the latched position (or half-latched if there is such a position) and needs to be released.
my latch tends to get stuck open and I have to use some lubricating spray on the inside as well as into the lock and it corrects it. As Paul said, try manipulating it by hand with some spray.
Yes they both look correct. The striker bar looks to be mounted curved "in" towards the box. Mine is that way on my 71.
Lube and work the button and latch by hand to make sure it is working properly. Then when closing it see if the door is touching the dash to soon (maybe an indication the hinges are off ? not that you have a ton of adjustment there). It that looks good I would adjust the striker bar a bit.
Sorry not the best pic, I was doing my glove box door/roll cage interference fix trick. Opens and slides over a bit and then opens the rest of the way like a champ now.
