buckva73
Give you guys a little update. I went out and bought a universal wire kit today. I figured that if I build them then I can blame me. Didn't look at the spark plug ends until I got home and they are straight. My plugs come out on an angle and you can do the math from there. Thank goodness only one plug wire is close to the header and I can make that work. On a bright note, the disco(old people)/rave(young people) under the hood stopped. Because the wire is so close, I didn't want to run it that long until I have a protector on the ends. I did run it long enough that under last nights condition, the headers would of started to glow. Tonight, it did not start. Mark; I happened to buy one today to see what the temps were and the little bit I let it run they were all around 300F. I am going to check the exhaust the way you said just to see. It is not a restricted system by any way but it is hard to hear under the truck because it has a 3" dump on it right now. To answer your question about where it started, yes, at the collector and worked its way up. Paul; all 8 were about the same. Yes I did use #1 pass front. It is the stock cam. I have a .750lift 112lsa solid lifter cam in a 347 that I can put in but I think its a little over kill.
I did think about the valves staying open but did not head down that path yet. They are stock rockers but are mounted on a stud where I could of tightened them a hair to much. I tightened them down on new lifters that soaked in oil but had never been run. I just tighten them down until I could not "roll them" with my finger. I was making sure that both valves on the cam were closed when doing that. The coolant temps went to 200 quick (3-4min) but then the thermostat would do its job. After that, if would go from 180 to 195 and then back down. I have a friend with a dyno and A/F that I can get on but I wanted to show up a little more prepared. The truck will be stored at his shop while I build our new house, so I can get some use out of it while its there. Let me know what y'all think with this new info. I cant say thank you enough for all the time y'all have spent looking over this with/for me. Buck
