GM Big Bearing Spindle Question
t120r
Can the big bearing spindles be machined down to the small bearing size safely?
broncnaz
Yes its only the inner bearing journel that needs to be turned down to bronco size. once done its basically the same as a bronco spindle as far as strenght.
Ranchtruck
Yup, did two sets and they came out great. I welded a flat plate on the end of one of the bearing nuts and center drilled it. That gave me a way to hold the threaded end centered with the big flange end in the chuck. I tried using just the chuck but the spindle kept tweaking when I tried cutting it.
I also had to make a special tool to cut the radius where the spindle shank meets the step. You don't want a stress riser there. I used a carbide to do the rest of it and polished the sealing surface while I was at it.
The other option is machining a spacer to fit on the stock bronco spindle to move the inner bearing over. There's still enough space for the seal to ride on, so that way works too.
T
t120r
Are the caliper brackets for these big spindle bearings useable as well?
broncnaz
yes the caliper brackets work fine. the only differance is that spindle with its larger bearing journel
