https://shop.broncograveyard.com/19...arter-Panel-Newest-Tooling/productinfo/14102/
https://shop.broncograveyard.com/19...arter-Panel-Newest-Tooling/productinfo/14103/
Replace the entire quarter panel is easier & will be straighter - not warped from welding. Looks like they're on sale right now too.
Thanks @Bejabrewer,
To get to the spot weld would I have to remove the passenger corner? and the hard top post slot?
Thanks @Bejabrewer,
L - LiftedGot to ask, What does LUBR stand for?
Thanks @BejabrewerTo get to the spot weld would I have to remove the passenger corner? and the hard top post slot?
I didn't remove the corners when I did mine - I cut about 1/2" from the seam & got to the spot welds that way. I was also dealing with a crusty, rusty, hacked & bondo filled rear quarter. Check post 22 from duffymahoney's build(Awesome job BTW)
http://classicbroncos.com/forums/sho...d.php?t=259028
that may be your best bet if the majority of your rear quarter is rust free. Just take your time welding it so it doesn't warp.
@duffmahoney amazing build!The aftermarket rear quarters don't fit great, in a perfect world stock quarters are much better, check my build.
@jamesroney That looks like a good way to get to those spot welds.You don't HAVE to. But unless that corner is perfect, it's way faster.
X2 on this...when it comes to bed corners.
I'd even try patching rust holes with metal and leaving them in place. I have 3 repops- 2 driver and 1 passenger in my shop and they are all different sizes and the body lines are all different. They must stamp them in China with worn out dies.
I'll post photos later of how not to make it look on my 77. It's embarrassing.
That's a shame. Who was just advertising using new dies??
Have you seen any of fritzee fabrication videos??
The best way you ask?H everyone,
What's the best way to go back to lubr?
- replace whole panel? Or
- patch the cut out piece?
