Going backwards again....
Tedster100
Chairman of the Bored
Well, after nearly completing my build I couldn't get the old 302 to run right. Pulled my hair out trying to figure it out cause they're really not that complicated. I completely we through every part of the bronco including the tranny & transfer case and cleaned, replaced or painted every part, nut & bolt. The motor was the only thing I didn't do myself and I finally decided that the only solution was to pull the motor back out and go through it myself so that I was confident I could depend on it and lookie what I found!
The motor had been rebuilt many years (19) ago and sat inside the whole time. Somehow the little bas#%$ds got in there and left me a baseball size glob of insulation. Also had some problems with valve guides that was causing the motor not to run correctly, thank God, otherwise that fiberglass would have eventually blown her up. That's exactly where I found the insluaton in addition to the wad in the oil pick-up.
So now I've got the block striped down and in the shop for some new bearings and a good flushing. Figured I'd replace the cam, valves & springs, intake and water pump while I was at it. At least now I'll be able to know it will be dependable. Go figure.
Tedster100
Tedster100
Only thing I can figure is the distributor was left out for a period of time but even that's a pretty small hole!
Heus33
Hmmm poor man's answer to a block heater?
Rig looks great though - love the stance with the rake and the hood - looks mean!
Viperwolf1
electron whisperer
Good thing it was a mouse motor and not an elephant motor.;)
Tedster100
Tedster100
Yep, rodent nest. Guess it's a Rat Motor! I've seen some strange things but this is by far the oddest find!
fordguy
go look at my build thread. i had a running bronco, now all i have is pieces and parts ;D
Tedster100
Tedster100
Nice rig, what kind of seats you using up front and back thanks.
ProCar Elite in the front and Bestop fold & tumble in the rear. With the height issue on replacement seats the ProCar's were the lowest I could find. I also groud off the rivets for the mounts and bolted the sliders right to the 1/4" plate that is the bottom of my cage.
I like them a lot but haven't put any miles on them yet due to my infestation..
bluesbish
Upstate New York
I see one of the rocker stud nuts is loose. did you do that before the pics or is that potentially the reason why it did not run right?
Tedster100
Tedster100
All the rocker studs were in tact except the cylinder with the bent rod, the rocker was actually off the valve to the side. I had loosened it up to look it over. I don't believe the bent pushrod and the fiberglass are directly related but the bent rod probably saved me from a really bad failure of bearings, rods, etc... Both valves on that cylinder had contact with the piston, still not sure why, it's torn down and at a shop I trust now. Going to re-build from the ground up to make sure it's going to last.
