got my alignment checked.......
jasondemitri
tacoma, wa
the guy said im almost 5 degrees off for the caster. it is at -1 3/4 on both sides. im thinking the po didnt install the c bushings correctly. it has a JD 3.5 lift. how many people out there haave done a 3.5 lift without having to get the radius drop brackets? any suggestions beside ripping the fron axle out and replacing the bushings? anyone know a good way to check them to see if they are in wrong or right?
thanks
jason
broncnaz
Its always a possiblity they were installed wrong or duffs sent the wrong bushings they should be 4 degree bushings for 3.5in lift. the only thing you can do is pull one on the radius arm caps
to check it the C bushings should have this side down or bottom side something to let you know which way they go mine did I think they also tell how many degrees they are cant remember
Its also possible that your Knuckles were a little off when the axle was built at the factory and you may have to get new bushings to bring you back in spec. Your alignment guy is right your caster should be between +2 3/4 and + 4 1/4
ken75ranger
Troy, NY
I would not be shocked if you have 4 degrees now and need to go to 7 degree. It's happened to a few guys here. Check what you have before you buy new ones.
fuseman
SoCal
I need to get mine done now as well. I got my tires at Sear's and they couldn't align it correctly and sent me to a 4x4 shop. I need caster and camber to correct and they say it can't be done, however I remember getting a part number somewhere from Napa for an adjustable camber insert. Anyone know of this or what I'm gonna have to do to make this right. I have a 3.5" sus. and 2" body lift with 35's. Tires aren't cheap and want to get the most out of them even if it means a couple of hundred bucks to do it the right way.
76RedRanger
Half of the C bushing is thicker than the other half. Much thicker on the 6-7 degree. If you look real close at the side of the bushings on your truck (in good light) you should be able to tell if the thick part is up or down. I have 7's in my 76 and it's real easy to tell. If installed correct the thick half will be on the bottom in front and on top in back. You won't be able to tell what degree they are but at least you'll know if their in right.
ken75ranger
Troy, NY
I kind of remember this. A couple of guys used some type of adjustable ball joint. Allen 69 might have been in on this.
Rustytruck
Dont waste your time checking bushings just get a set of 7 degree bushings for the front and get a set of BC broncos rear offset bushings and put them in. Everyone who uses less angle bushings end up changing them. the stock caster setting is even marginal for stock 29 inch tires without a lift.
lars
Been here awhile
NorCal flatlands
Good luck getting the caster right. I've got 4 1/2" BC coils with 7 degree bushings. With that setup I still only had about 1.5 degrees positive caster. I added these http://www.cafes.net/epp/CasterCorrectors.htm (the 1.5 degree versions) which got my caster to about 3 degrees. It's still not enough. Like Rustytruck wrote, the OEM spec is marginal even for a stock Bronco. Interesting that in 1978, the first big Broncos were spec'd with double the caster (about 6 degrees) even though they still had nearly the same axles and suspension geometry. 78/79 Big Broncos used the same radius arms, but mounted lower relative to the axle. My theory is that EB's had a marginal caster spec because they had manual steering. More caster makes for harder steering. Big Broncos came stock with power steering, so it wouldn't have been an issue. Next month I'm going back to stock spec C bushings, then cutting the inner knuckles off the axle tubes and rotating them back to get 6 degrees. I've been wanting to do that for a long time, everyone I've corresponded with that has tried that approach has been extremely pleased with the results.
kwspony
Roseville
HEY LARS
would cutting off the axle wedges and repositioning them do the same thing for the caster? I have a D44 that the PO cut off the wedges and track bar mount to put on a D60. I will be welding them back on in the future and need some direction in doing so. Will probably buy the disc brake setup and new gears first but will have to do it sooner or later.
77TexasBronc
Baytown Texas
Have the same setup as you and had the same problem. I ended up putting on the adjustable drop bractets from Duff to get it right. The only bad part is they hang down about 6" under your frame rails. It didnt take me long to realize this sucked on the tuffer trails. I have cut the drop bracket off and Iam waiting on the UPS guy to drop off a set of the duffs extended radius arms and will be starting over again I guess.
Sounds like Lars has a good plan also.
good luck ;)
