OK, so I got the electric fuel pump mounted and wired in, and it works great - feeds the carb, fills up the bowls quickly, and the Bronco starts up better than ever.
However the 351 that I swapped in now runs terribly. Setting the idle at anything under 1100 RPM causes it to stall out. If I have the idle set at 800 RPM or so and then feather the throttle at all as it is about to die, the RPMs will shoot up to 1500 or so and sit there for a few seconds before dropping back down to the 800 I have the idle set at.
With a vacuum gauge hooked up to the manifold, I have a steady 17 pounds of vacuum at 2,000 rpm, but at lower idle speeds I've got 5 or 6 and the needle is kind of erratic. I'm not sure if this indicates a vacuum leak or is just because of the RV cam.
For the heck of it, I took it for a drive around the block and it stumbles upon acceleration. At idle the throttle response is great. Under load, it's terrible. It seemed to want to stall out all the way around the block. Forget trying to take it on the freeway.
I have not gotten a can of carb cleaner to spray around the manifold and vacuum lines, but plan to. Just looking for any further suggestions on what to check for these symptoms.
