Granny Low First Gear?
RrCoX22
Los Altos, CA
What does this technically mean? All first gears are normally set low in gearing but what's the "granny" part of it mean? Extra tall 1st gear in the tranny?
wildbill
Old Bronco Guy
:D :D :D Its a truck 4 speed G/L is real low it works as a 3 speed on the street unless you run big tires or have a big load.%) %) %) Bill %) :cool: ;D
bmc69
the trannys with 'granny low' have a (usually) unsynchronzed 'first' gear that has an extremely low ratio as compared to a typical tranny. Instead of something between 3:1 and 4:1 for first gear, they are even taller than 6:1. (6.32:1. 6.69:1..numbers like that) Technically, it is an auxilliary low gear, not really 'first' gear, and the rest of the gears (2,3,4) are the only gears normally used for driving and those three gears have ratios typically found in three speed trannys.
Buldozer
Bronco Virtuoso
God's Country
Yep, just what the others said...if the first gear is aproximately twice the normal first gear ratio, it would be considered a "Granny" low because Granny moves rather slow you know. First gear in a NP435 would be considered a "Granny". Funny huh?;D
Like mentioned...
Just an abnormally low gear that is not used in normal unladen driving conditions.
Many times the shift knobs list L-1-2-3-R as the gear choices.
When used with (over) loaded trucks it is just there to get the load rolling so you don't smoke the clutch in the normal first gear.
Used in industrial settings when vehicle speed is needed to be kept low and avoid clutch slipping.
On farms I have known people to put the truck in low gear, get out of the truck and throw feed from the back as it blindly idled across the field. Slow enough you can get away doing that.
I set up a water truck for my uncle and the low gearing is so the truck goes slow enough to water the ground.
Granny term is simply becasue it is so slow. I always thought of it as how fast granny drove, slower then normal.
sprdv1
REBEL
HEck yeah, for steep inclines, let it creep down the hill, and up too ;D
so this gear would typically be used for wheeling?
Very much desired for wheeling. It slows you down. multiplies torque like crazy. Put it in granny, and idle over stuff. To an extent, lower the gearing the better. Wheel spin is avoided and wheel spin does little good when trying to be nice to the ground and go over it and not through it.
kbldawg
Marshall, AR
Does the NP435 have more than one first gear ratio?
I was trying to run down some ID Tags on the NP435 trannies I bought recently and found this...
http://www.uglytruckling.com/Technical Topics/NP435 mods.htm
PTO for NP435:
The NP435 Gearbox uses the 352 series Chelsea PTO. There are two gears that must be gotten with the PTO. An idler gear, which is the same for both the 668 ratio and the 456 ratio boxes and an idler drive gear for which you will have to specify the input ratio. If your gearbox has its metal ID tag you can determine the ratio as follows; if the tag says 435L it is a 668 ratio box, if it says 435A it is a 456 ratio.
One of my trannies has the "L" and the other has the "A" on the ID tags. I counted the teeth on the 1st gear and they're both the same.
