Grill Chrome trim
Ohio Bronco 21
Cleveland
Does anyone have pictures of a Grill that has the chrome trim option but it is off in the picture? I am looking for the placement of the holes for the trim. I need to drill some. Thanks
thegreatjustino
Red Head Grease Monkey
Stockton, CA
Not sure if this helps. The retaining clips are still in the holes.
Ohio Bronco 21
Ohio Bronco 21
Cleveland
Thanks, I believe I can see where they go. At least I know the holes are in the "Body Color" area not the center section "white"
pcf_mark
I put the trim together and then place it in the opening. I moved it around until it was even all the way around. Then I traced the inner and outer edges of the trim and put the holes in the middle. I used nylon 1/4-20 bolts and nuts. I had the trim then on the grind to make them a little shorter to fit in the slot. That let me have some adjustment, no rust and dirt cheap versus the factory fasteners.
