Grill color change line
SteveC
Tuscaloosa AL
Can someone snap a couple of up close photos of their grill? I need to see the color change area that goes from body color to argent grill color for repainting.
Thanks!.
Bronco Junkie
So Cal Broncos
Here ya go.
SteveC
SteveC
Tuscaloosa AL
Thanks but I need really up close. Close enough to see where the body color stops and grill color begins. Like at what point around the "ridge" around the grill.
englewoodcowboy
Lick Creek Restorations
Its pretty easy but it is done in 2 ways, does your grill have the chrome trim ring that separates it (Most common with Sport models as well as the upgraded Rangers, Explorers, Stroppe, Special Decor etc.) If it is a plain bronco with no trim, the line is defined in the drill stamping, you cannot miss it. If you have the trim, you will need to test fit the trim to make some marks so your color line is hidden behind the trim etc.
76 bronco J
>> my explorer spec/trim bronco came from the factory with the later explorer hood/side stripes along with side moulding/trim.... no grill trim, window/windshield trim or chrome headlight bezels.....
