Eoth
- Mar 10, 2004
- 1,680
I swapped my 302 for the Explorer 5.0. Now my starter makes a metallic grinding noise when engaged. It starts the motor fine and stops when I stop cranking. I imagine that it has something to do with some type of difference between the 28oz original and the new 50oz flexplate (FRA-214)????
I took the starter off and inspected everything an reinstalled (same effect).
BTW the transmission is a C4.
Looking at the starter gear I see that it is worn but I wouldn't call it "bad"... I do see what appears to be scraping on the edge of the flywheel teeth. It is just a worn in starter gear having issues with sharp new flywheel teeth?
