Bronco started right up this morning. Stopped by the store on the way to work. When I went to restart the starter made a grinding noise on the first attempt. Turned the key a second time and Bronco started right up with no grinding.
Is this a sign of a future starter problem? Should I replace the starter? Anything to look for (flywheel or starter)?
I would like to fix this before it becomes a real problem.
Bronco is a stock 1970 with a 302/3speed and 65,000 original miles. Nothing has been changed or replaced except for regular maintenance. I have been driving regularly since May without any issues.
