GT40P headers info again
burntfish
ouray, co
There is a exhaust setup for sale in the classifieds that has hooker long tube headers and a full dual exhuast. I am trying to figure out if the hookers will fit my GT40P heads with some modification if needed. I did a search and found 1 person who said they ran these on the GT40P heads and worked. Before I agree to buy them I want to make sure they will fit. My specs are 97 explorer GT40P, C4, dana 20, 5.5" lift, 2' body, no inner fenders. Any help would be great.
surfer-b
Unless you are just set on using headers the factory Explorer manifolds for the 40P's fit just fine, and with the body lift you have you will have plenty of clearence.
burntfish
burntfish
ouray, co
I am trying to do it cheap. I can use the stock setup. The cost of making a exhaust pipe and mufflers for the stock setup will be more then the headers and exhaust this guy has for sale. If they don't fit or I cant get them i will use the explorer manifolds.
WorkerBee
Northern CA
If you're trying to go cheap I was able to grind my stock manifolds and they fit fine. I used the high heat socks and so far no issues.
