Guesses on this uncut lift and tire size?
toro
Love this uncut’s stance. I saw it here while looking for wheels: https://www.carid.com/us-mags-wheels/u101-indy-1pc-polished-452578.html
Bajabrewer
My guess is a 2" body lift - look at the gap between the bumper and grill. Also if you go to that link & see the pic of the back of the same Bronco you can see the same gap at the rear. I think the tires are 31" based on the fact that I've had that size on a couple different Broncos. My 66 has a 1 1/2-2" suspension lift & 31x10.5x15 tires & the gap at the rear wheel opening is about the same as the truck you posted.
chuckji
SE Michigan
For sure more than 1” body lift. Probably 2” body lift with 31” tires as Bajabrewer said.
Mikesimp70
Definitely 2+ body lift and likely 4.5SL. I think those are 33s. Quite a step to get in there and for sure higher than my 1BL, 2.5SL and 31s.
T-7ToNewOldB
Uncut
Here are 31s on a 1" body lift. 1.5" suspension lift. On 16" Rims.
ngsd
For reference, this is a 3.5" SL with a 1" body lift on 33's
Bajabrewer
After looking again those probably are 33's - assuming the wheels are 15's the tire on the blue one looks taller than the 31's on 15's on my truck here is a pic of 31" BFG mud terrains on mine & the blue truck
ptwist
I’m running a 31 with about 2.5 in suspension lift. Just checked the other day and it’s got a full 19 in travel in the rear without rubbing. The only spot I have any issue is the front rubs on the radius area at full lock.
