Guide plates for GT40 heads
EPB72
Pleasant Hill, CA
If all you want is a simple low RPM engine, why not just use simple stock valve train design?
Agree with above this seems the best option,,,or possibly look into the 93-95 cobra r rocker setup full roller and retains the pedestal design no guide plates.....My experience with the kit mentioned is a customers stang was towed in ended up pulling right side valve cover and found the pushrod guide bushing in pieces laying on head ,,rocker slipped off stem pushed on retainer lost keepers and the engine was making some pretty loud noises .
J
jckkys
The 93-95 Cobra 5.0, and the '95 CobraR 5.8 engines used Crane aluminum full roller 1.7 rocker arms that were bolt down and had to be adjusted with shims. The aluminum rockers won't fit under the stock steel valve covers without removing the baffles. The 5/16" bolts never pulled out of the heads despite the 1.7 ratio, stiffer valve springs, and much higher RPMs than my engine. Dodge Magnum 360s and Olds big blocks also use 5/16" studs. No problem there either.
I never liked adjusting valve lash with shims. A regular valve lash adjustment nut makes a lot more sense. Since I already have the hardened push rods, and Comp Cams Magnum roller tipped rockers the fit under the valve covers, simple steel guide plates would complete the valve train. They're the cheapest component of all, but no one makes them. I'm not going to pull my already torqued down heads to drill and thread them for 7/16" studs. I've got another plan that should work. I'll share it, if it does.
