H4 conversion kit
As far as easy to install goes extrembronco, they all "should" be the same. I say "should" because even though it's an industry standard lamp size, there are still a couple of brands out there that don't fit easily (depth-wise) without some cursing. I can't remember which brands though. I seem to remember that one of the cheapy brands gave one of the members here a hard time when he went to install them, but most of the others (myself included) have not had any issues with the install. A little surprise down the road with the old headlight switch and wiring in some cases, but for the most part it's a slam-dunk.
I've personally tried several brands in mine and had no fit problems.
Try doing a search for this subject and sift through all the reports and see if you can find the pros and cons.
And stay tuned to the mass-buy that Skuzzlebutt linked to as it should be coming about sometime soon (picture 50 people knocking on wood! lol) and is a decent price on a premier brand. There ARE less expensive lights out there for sure, but not all are of good quality or good light patterns which seems to be the main selecting point when choosing one of these setups.
Another good choice now for a decent price with a seemingly high quality product is the Delta brand at BC Broncos. They're not the cheapest either, but he's been using them now for a few months and is happy with them. I haven't tried them myself, but the reports are good.
Good luck with the search. There's been mucho discussion about them in the past.
Slick
Petoskey, MI
What do ya need to do about the pig-tail and re-lays??? I understand you'll fry sum-thing if you mearly just plug in the H4's into your factory switch w/out any modifications...
:cool:
Skuzzlebutt
PhD, Dr. of Broncology
Honeymoon Bay
That depends on the bulbs you put in. A 55/60w H4 draws the same power as an old fashioned 55/60w sealed beam lamp. If you install a 100w (or higher) bulb, a relay conversion would be in order. Even if you didn't, the headlight switch has internal cicuit breakers that will protect the system from damage.
mitzel
Googleplex
> Plus DOT approved:
IMO I highly recommend looking into an E-code light rather than US DOT. the beam
pattern is much better controlled, and especially if you plan to go with a mega wattage bulb
they significantly reduce blinding oncoming cars.
