...this isn't the venue to teach a class.
You noticed that? Good.
The short answer is, relays are available in all sizes and specs...
So are switches.
...and I purchase the correct ones for the application.
So did Ford. But in many cases, they engineered their own switches, and then bought those switches from companies that could meet Ford's specs. Do you ever test your switches to make sure they meet your specs?
...it would melt within 24 hours with the wrong switch.
So if it lasts 68 years, and is worth ~20x as much now as when it was originally sold, it's probably NOT the wrong switch. Especially a modern copy made with better materials, better engineering, and more testing.
With relays I also control the gauge and length of the 12 volt feed into the relay.
Ford did that with the switch & headlights.
I make sure its sufficient and its also dedicated to that circuit.
Yeah, they did that, too.
The OEM headlight switch pulls its 12V from a feed that is common with the feed to the fuse box and fed from the battery, starter or alternator and depends on the quality of that connection.
So yours is NOT coming from the battery, and does NOT depend on the quality of your connections? Are you a better engineer than Ford hired in the 50s through the 70s? Are you spending more on testing on your designs than they did on theirs? Are the vehicles you designed & built lasting as long as Ford's?
I guess I went to a different class than you because I'm sticking with Ford's designs whenever possible. And even today, they don't build headlight circuits the way you're describing. Why do you think that isn't?
Tobtech, trust me you are wasting your time arguing...
Right - it's a discussion forum. He should be discussing.
