Hanging a hard top
trailpsycho
Hi all. While there are many ways one could hang there hard top for storage (2X4s, Lange Originals hoist a top, etc), does anyone know if or has anyone tried suspending it from a roof rack (gutter-mount). It is a great excuse to buy a roof rack system, will be multi-functional and easy as pie to raise/lower off the truck. I know that the gutter mounts can take alot of weight in downforce (upwards of 500lbs), but what about 200-250 lbs in the other direction. Any feedback would be much appreciated. I am a little tight on space and need to get the hardtop out of the way so I can spread the rest of the truck all over the place. TIA.
rayc
Western Oregon
I don't know if I would try hanging a stock steel top from just a roof rack system, unless you have a nerf garage floor. Those things are pretty heavy, although I commend you on trying to find an excuse to buy one. Just tell your wife that buying the rack is the only way to hang it, and then "supplement" it with some ratchet straps. Here is what I used, and it works pretty good.
Southerner
It's definately not designed for that, but I'm just stating the obvious. Call one of the companies (Yakima, Thule, etc.), they should be able to give you better insight. I've got to say that is a pretty good idea, let me know what you find out. I've got roof racks on two vehicles (One on my eb, and one on a truck camper shell), and that sure would make it easier.
trailpsycho
trailpsycho
Ray,
Thanks for your response. I originally thought of the same sort of thing, but my neighbor (a former heep owner) had a hoist a top brand new in the box (except for the frame), so I got it set up and since I am hoisting from a single point directly above...I am not so sure I want the straps making sweet love to my top as they wrap around. Also I want to be able to raise and lower it by myself...friends seem to disappear when its time for installation/removal, but reappear upon removal...hmmm...connection? Maybe I could use the rack for raising/lowering and some 2X4s, eyelets and straps for long term storage...yeah thats the ticket. Anyone else got any suggestions?
trailpsycho
trailpsycho
The Yakima rep said he would not/could not give me a definitive on whether it would hold long term, but did say that "think about the up-force generated by the wind on the highway". So, yeah, I think it will work. I am going to give it a shot, at least for raising and lowering, then like Rayc's setup with straps to the rafters. I will take pics as it comes together. Keep the feedback coming.
rayc
Western Oregon
Let me know how it turns out. It is a good idea, but I feel for safety reasons you would definately want to supplement the strength with straps or something similar. a roof rack would sure solve the problems I had with having my wife help me hold the top up while we slid the braces between it and the bed rails.
Are you leaning toward Yakima or Thule? You may also want to check out the Con-ferr racks. www.con-ferr.com I have always wanted one of those racks.
Good luck
Yellow75
Sioux Falls, SD
I store mine stood up on end resting liftgate down on some old car tires. Just threw an old blanket over the top so it won't get scratched from the wall. Works fine and you won't end up bleeding from your eyeball after you run into it in the garage!. That is unless you have a 10'+ ceiling.
trailpsycho
trailpsycho
The con-ferr product looks pretty good. I dont like the fact that they are modular though (3 pc joined by bolts?), I am sure I am full of it, but it doesnt seem as strong as a single unit. I liked the Wilderness racks best. I have seen a couple up close; they are some beefy-muthas. They come in a variety of dimensions too, but are expensive. I saw a post from Sept where someone was selling/taking orders on roof racks on E-bay. I saw one called bazkets-of-steel made from 1/2 or 3/4 sq tube and the steel mesh/grate you see on the floor of trailers. The guy coated them with rubberizer and they had a built in faring; they were pretty cheap too, especially with the Canadian exchange. By the time I could afford it, I couldnt find him on the web anymore though. Currently, I am just going with towers and crossbars; the actual rack will have to wait. I think getting the bronco torn down, motor, trans, etc are a bit more of a priority. I just want to get the roof up, up and away so my shop can come together.
My garage doesnt have a finished ceiling, so we put in some (2) 12 ft 2X6s across up high to brace the roof, then a doubled cross beam and attached the main pulley there. Hopefully, I will get a chance to finish that up this weekend and will post pics or at least give a report. Thanks for your interest.
