Hard EFI lines
bannind
Is it possible to do hard lines for my EFI along the frame following the original path? I would like to utilize a set of the stainless clips I have in the parts bin from BCBronco's and then just do AN fittings on the ends. I would then run 2 feet of the high pressure rubber lines on each end to do the final connections.
possible? thoughts?
thanks,
dan
Timmy390
Conway, AR
BC sells hard lines that run the length of the frame. I made my own using BC's as a guide. I used beaded SS to connect from hard lines to fuel rail. AN fittings used for all connections
Tim
fordguy
i am not following how you connected to the fuel rail
Timmy390
Conway, AR
SS braided line from hard line to the AN fuel rail fitting. Here is a pic of the lines
Tim
fordguy
you got me when your post said beaded SS, braided makes sense. lol
bronkenn
Bronco Guy
Southeast Ohio
I ran stainless hard line on top of the frame but would be same process to run on the side of the frame. Put a tube nut on the line and a 37 degree flare and a coupler to transition to braided line. Ken
